tarheelebbtide
- Jul 4, 2008
- 94
'93 Mercruiser 350 Mag 5.7L with an Alpha 1 gen 2 outdrive
I need to pull my outdrive off to do replacement of the bellows, check and grease everything, etc. Some of you may remember I had a near sinking and you helped me get the engine taken care of. Well, I'm sure the bellows are full of water as well so I need to get that off of there so that I can replace and check for rust/wear on the joints and bearings.
My problem is that the bellows kit isn't in yet and it may get cold enough here this weekend that I need to winterize, etc. If so, I'll need to fog down the engine and all that. Can I run the engine without the outdrive installed? I assume there is simply a pick up pipe that carries the water from the outdrive through the transom and into the engine. Can I just stick a water hose there? Thanks in advance guys.
This is my first attempt to remove the outdrive myself.
