Winterizing Questions
Wellcraft20
I just recently bought a boat with a 1989 175 Hp Evinrude outboard. I am not sure how I should winterize the motor (do I need to drain any water, lower unit oil, gas, etc.). Any suggestions would be greatly appreciated.
dehydrated
Re: Winterizing Questions
welcome to i boats if you look in the sticky file you will find what you need .it is pretty simple on outboards fuel stabilizer added to fuel draining and refilling lower unit is always a good idea to do in case there is any water in lower unit .
