anodes for volvo penta 290
jfalco
what anodes do i need to replace on my 1988 volvo penta 290, also is there a special puller for my prop , is the nose cone an anode? the boat is in salt water
Don S
Re: anodes for volvo penta 290
Single prop or DuoProp drive? Anodes are different, neither has a nose cone that is also an anode. The prop/s just slide on and held in place by a threaded nut of some kind, and no not require a puller. If you need a puller, the prop is froze to the shaft. May have to destroy the prop to remove it.
In salt water, you need to remove the prop/s yearly and grease the splines.
jfalco
thanks don s its a single prop (sorry bout that), i bought a anode kit and it came with one for behind the prop, another bar anode that i know where to install and a small triangle anode that i cant figure out where it goes, where does this go or was it a mistake, it was in a seperate plastic container
jerryjerry05
The triangle is a steering fin,Look at the pic. #7 J
Don S
The trim fin on a Volvo isn't an anode,
I don't remember any small triangle shaped anodes on a 290, could you post a picture of what you have? Was there a part number on that container?
Does it look like this?
attachment.php
jfalco
sorry it took me soo long to reply, new computer took a few days to get up and running, Don that pic is not what i have, im thinkkg it was a mistake but the number on the part is cm8 72793z. thanks again for all the responses
Don S
That is not a Volvo number, so hard to say what it is. Post a picture of it. That would cure many problems.
Don S
Never mind, just remembered the CM is for Canadian Metals and they make aftemarket anodes.
Yes, it shouldn't be with your kit, and is a mistake, and it is for the XDP drive.
Look at this.
attachment.php
attachment.php
jfalco
Thats it !!!! Spare part. Thanks Don.
Don S
Spare parts are supposed to be for able to be used for your boat.
Those are small enough to be used for sinkers in deep water ........
