Regarding Zodiac RIB boats. It is possible to change the tubes on the hull.
While the hull has a number on it that tells the date of manufacture, is there a similar number (or code) on the tubes that tells you when the tubes themselves were manufactured?
You could have a boat where the tubes were replaced and there could be a big difference in the age of the hull versus the age of the tubes.
Thanks.
Thanks.
