Re: Spark Plug Wires
So that means they shouldn't use resistor type plugs then too, correct?
My understanding is that the resistor type wires do not withstand the vibration. Right or wrong I dont know.
Resistor plugs is another topic.
Suppressed plugs may be needed to suppress radio interference
The old method of suppressing interference was to incorporate a resistance in the plug.
These are fine with points ignition.
However OMC CD ignition systems do not work well with resistor plugs ( see
http://members.iinet.net.au/~pauldawson/iame26-spark-plugs.PDF ) so if suppressed plugs are required to prevent RFI they must be inductive ( low resistance) types ... the Champion "Q" or NGK "Z" series.
I guess The CD ignition will not like resistor leads either!
VRO & OMS systems require suppressed plugs to be used and since motors with VRO or OMS will in fact have CD ignition it follows that "Q" (or "Z") plugs must be used.
Interesting to note that other brands of outboard motors do in fact use resistor plugs. Something quirky about the OMC CD system presumably!
