1988 johnson 140 vro
Last time I took it out it ran perfect for 10 seconds WOT then died and I got no spark. Took it home and tested it and noticed spark was coming and going on all 4 cylinders. Ruled out ignition switch, ppack, ignition coils, plugs, wires. Finally this weekend I popped fly wheel and inspected stator and timer base. Stator has a chip on the top edge and you can see a white discolored spot in the flywheel (picture). Timer base looks ok. I ohm tested stator and I got 95 between orange wires and 480 between brown (amphenol plug). Couldnt get good reading on timer base. Anyway I order a new stator its on the way, but now Im afraid it may be timer base. The intermittent spark happens on all 4 cylinders when cranking. At this point, It can only be stator or timer base but I guess Im pissing in the wind hoping its the damn stator. Can this little nick on the stator be the problem??
