Prop/RPM Question
rutcutter
Although this does not apply to my boat I was thinking about it over the weekend. My question concerns 2 stroke and 4 stroke RPMs. I understand propping a motor to run in the upper limit of it's RPM range to avoid lugging the motor. Is this as important in a 4 stroke as opposed to a 2 stroke? They are certainly 2 different animals. In the 4 stroke it seems to me that as long as you do not exceed max RPMs that it would not be as important.
Your info is greatly appreciated.
Silvertip
Honorary Supreme Mariner
Re: Prop/RPM Question
Yes it is just as important and what makes you think that it isn't? It doesn't matter if the engine is a two stroke, four stroke or a wankel -- if that engine cannot reach the manufacturers maximum recommended WOT RPM you are lugging the engine. Four strokes don't like to be lugged any more than a two stroke. Besides, you wouldn't be able to reach the maximum potential for the boat, engine, prop combination. All three engines can suffer damage from over-reving as well so under propping is just as bad as over propping.
Frank Acampora
It is MORE important to prop correctly with a four stroke engine. The four stroke engine only has one power pulse per cylinder for every two revolutions while the two stroke has twice that.
rutcutter
You are right Frank and I did not think about that. I appreciate you guys comments.
