Volvo Penta engine change
peteflint
I am looking at changing my 5.7l V8 engine. There is about a foot gap to the front of the engine, can it be removed without taking the leg off?
zbnutcase
Re: Volvo Penta engine change
Year, model, and serial # would help, but if it's an SX series yes it can be done, but why fight it when the drive comes off so easy?
bruceb58
1) You want to take of your drive annually anyway to check u-joints and gimbal bearing.
2) If you are reinstalling a new engine you have to check alignment so the drive has to be off for that.
peteflint
Thank you for taking the time to answer. I thought it might be a lot easier just to take the engine out and replace it with the leg on but it seems that I will have to remove the leg now, more work than expected so not sure I will be able to do it myself and the engineers in the location charge a fortune and take twice as long to do a job to hike the price up. Thanks again. Pete
bruceb58
Taking the drive off is an easier task than taking the engine out. Just for clarification sake, what Volvo drive do you have?
Don S
Depending on the type drive, you may only have to remove part of it. That is why people keep asking what kind of drive.
peteflint
Not 100% sure but think they are 290 leg with duo props if that helps. It is on a 1990 Beneteau Flyer 35ft Sports cruiser. The engine number is 4100108380 AQ271C. Thanks Pete
Don S
You do not have to remove the complete outdrive on that style outdrive. Only the upper gear box. Here is a drawing I made to show how to remove the upper.
attachment.php
Once you have the upper gear box removed, you have 6 bolts that hold the clamp ring on (They have locking tabs that have to be straightened out).
Once those six bolts are removed, you can pull the engine and flywheel cover out as a single unit.
attachment.php
PS: You do not have a gimbal bearing, nor do you check alignment on your setup.
peteflint
Thank you for that, it looks a lot better than I thought. Pete
