starcraftkid
- Jul 5, 2010
- 224
I looked at an old boat today with what the owner says is a 1970's or so era 40hp 2 stroke twin cylinder Tohatsu.
The motor has no numbers anywhere on it that I can see?
The motor is dark gray with a lighter gray cover with the '40hp' logo in dark gray.
The motor seems to run good, but I don't see a tell tale stream anywhere? Did they have one? It did push water out of the upper exhaust relief ports when running. I only ran it for a 1/2 mile or so but it seems to be OK but I'm a bit cautious since it's so cheap. The boat and trailer are rough, but the motor seems decent. I'm just wondering at this point if there's something wrong with it I don't see? A call to the nearest dealer got me nowhere.
How old could it be? It resembles a 1989 Nissan motor I found online but the cover is shaped a bit different.
It's also got makeshift controls, the ignition switch is on the dash, but the controls look like old Mercury or maybe aftermarket. They may have come from the boat back in 1958 or so.
What did Tohatsu use for controls?
