Re: Please verify my HS needle (Pic Attached)
Well shoot, here we go...
I removed the carb this morning, and took off the float bowl. The high speed nozzle was free and clear. In fact, that hole is so big it would take a lot to stop it up. It has the old cork float. The float was not soaked full of gas. Doesn't matter much now as I accidentally broke the #$%$ out of it anyway. It was pretty fragile. Now, I did have a Sierra carb kit (the one without the float included). The kit contains a needle, needle seat, washer, and a tiny wire/spring clip. The BRP drawings do not show this little clip/retainer/spring. The needle/seat valve in the carb is missing this. It's my understanding that you need that in order for the float to pull the needle out of the seat. I installed the new needle/seat valve and actuated it with the float with and without the retainer/spring/clip while blowing into the fuel inlet nipple. It worked better with the retainer/spring thing in there.
Can anyone confirm these findings? Since I didn't find the high-speed nozzle to be blocked I'm still not sure why I'm not getting enough power/revs at WOT.
Almost forgot to mention...
I bought another carb on eBay for a nice price. I cracked the little plastic control panel 4 years ago when I let go of the starter rope handle. The "new" carb has a control panel intact. It also comes with a new unopened OMC carb kit with a float. So I have that on the way.
