Re: To Fog or Not to Fog F150?
Thanks for checking that rodbolt.
So after all the F150's fluids are changed oil, (via vacuum not draining), lower unit oil is changed, and all fittings lubed etc.
In this order I then do the following.
1: Drain fuel cup and fill with mix.
2: Drain VST and fill with mix. (how do I fill the VST? my remote tank does not have a primer bulb)
3: Run engine on muffs with remote tank mix for 10-15 min @ what rpm?
4: After the fogging run I leave the fuel mix in the VST and cup all winter.
When you say " DO NOT run F150 on a flusher at 1500 rpm's for 15 min" your talking muffs correct? Is this because it will not provide enough water pressure to cool the F150 at this rpm?
So I understand fully, filling the VST and fuel cup pre-fogging run on the F150 is to assure the mix gets distributed, due to running the F150 for 10-15 min only burns ~ 1/4 gal of mix.
I appreciate your wisdom and patience with this rodbolt, I just want to protect my engine, and make sure I do this correctly.
