kfa4303
Banned
- Sep 17, 2010
- 6,094
Hi all. So after a couple weeks of effort and TONS of help from here at iboats, I got my old 1966 33 hp running like a champ (in the tank any way). Can't wait to get her on the water and get everything set up just right. The only problem is that the throttle linkage from the tiller drive to the motor does not work properly. The gears and teeth don't quite sync up. The main problem is where two little gears merge at the hinge on the tiller. I can twist the throttle and get the gears to interlock a bit, but then they fall out of sync again :/ Is there any way to rebuild/adjust the rods and gears so that they will all interlock and interact correctly? Thanks for all the help forums.
