txarmydude
- Oct 24, 2010
- 119
I have a Mercruiser 888 in my 18 ft 1977 Cobalt. I have no idea the condition of the engine, just a click from the solenoid when trying to start it. I just bought this boat, and have been working on the hull and interior since I got it.
My question is this: What is the cheaper route to take to get this thing running?
A. Should I drop a re-manufactured 888 in it? ($1300) Worth it or not???
B. What about a used 302 out of a truck/mustang? This boat is fresh water only. Will ford engines work? A used Ford motor could be acquired for DIRT CHEAP!
C. I understand there is a 898 option on this model that is a GM version of the motor. Would that be a cheaper route to go?
D. What about a valve-train -- cam, lifters, rods, springs, etc? How can I find out which parts will fit these heads? Any info on heads would be appreciated!!! Like, is there a Ford equivalent that has all the same bolt holes?
Oh yeah, and how would you get the motor out? Would a cherry picker be able to lift the motor high enough to get it out of the boat???
Thanks for your advise!
