Re: impeller change
Only if the seal is cracked or torn. Even then, the top seal is redundant. The impeller itself seals against the case so very little water pressure, if any, is against the seal. Think of it this way: There is no seal on the bottom plate of the pump and it functions quite well, thank you.
