WellyMart97
- Aug 22, 2010
- 6
I have just bought in mid September a 97 Wellcraft Martinique 2800 with a Merc 7.4 EFI, 400 hours, Bravo 3 drive, engine serial:0K151492, drive serial:0K182146 used in saltwater which has developed a loud ticking noise. On the way back in this past Sunday it started as a very quiet tick with a frequency at roughly twice the engine speed I could barely hear until the last time I came off of plane. Time between barely audible and quite loud is less than one hour of runtime, if that. Now it does it all the time in or out of gear but oddly is louder off the back of the boat than from the engine compartment. Performance is completely unaffected. I have lurked a ton around here for months just to soak up as much as possible before I actually bought this boat so I knew what I was getting into and my research from here has led me to believe the exhaust shutters are making this nasty racket, does this sound correct? Is there anything I can do to verify? If they need replacement where do I find them, not only on the boat, but to buy from? Better to get Merc ones as opposed to aftermarket if even an option? Is this a job for an amateur like myself? Am I even remotely correct? And on a side note I would like a Mercruiser service manual before I touch anything especially with winterization around the corner, I have read I should find a Merc one because the Seloc's are iffy as are others. Any help is obviously appreciated. Thanks.
