rectifier question
jvstream
What purpose does the electric rectifier serve on outboards? Thanks!
mables
Re: rectifier question
The rectifier is the same on anything it converts AC to DC to be used to charge the battery. While they all serve the same purpose they aren't all interchangeable some may be 2 or 3phase or have built in regulators to keep the volts under 14.
jvstream
Thanks! What purpose then does the powerpack serve?
dehydrated
also depends on what your working on for interchangeable parts
mables
Depding on what you are calling a power pack is depnding on what purpose it serves, some are just terminals that connect all of the other components together, some people call the amplifier on these older motors a power pack but it is quite different. If you are referring to a specific motor then the year make and model would be helpful to identify everything for you.
jvstream
Thanks guys. I am working on a 1995 115 hp Johnson outboard.
boobie
You may want to give us a little better explanation of why you are asking these questions. That way it would be eaiser for us to help you.
