bish bash bosh
- Oct 26, 2010
- 2
Hi,I have a removal problem,the outdrive is stuck in reverse,upon inspection cable has snapped.I have proper manual covering my model and it says outdrive must be in neutral for removal.Have tried pulling off outdrive but appears stuck with only about 1/4 inch movement is it because outdrive is in gear or is it the normal stiff removal as it has not been off for 2 years?
Many thanks
Many thanks
