PuddleJumper
- Jun 6, 2005
- 314
Looking at buying 2001 boat with single 502 mercruiser mpi There is a small leak under the exhaust manifold. I couln't see a crack and there are just droplets there with very slight hint of steam. The mechanic at the marina thinks the problem is a plastic casting plug leaking. States the fix is removal, drill out and put in brass plug. I'm hoping he is right as this would be way cheaper if manifolds (on inspection when they are off) don't need replaced. Has any one heard of this plastic plug issue in mercruiser exh manifolds?
