feathercrafter82
- Oct 24, 2010
- 2
I recently bought an old super seahorse 40hp as a "parts motor", but immediately noticed that it wasn't locked up and had good compression, so I replaced the fuel lines, cleaned the carb, checked the points; and got it to fire. After she turned over, I replaced the impeller and got her to run for about 30 seconds, but shut her off after I didn't see water coming out of the pee hole (or what looked like a pee hole). The motor felt like it was indeed cooling, and I pulled the lower unit off again and this time hooked a hose up directly to the copper pipes where they would normally couple to the water pump housing. The water seemed to be passing through the motor just fine, but again, only exhaust was coming out of the pee hole... So my question is: is this normal? And if not, what are the potential causes of this? I am much more familiar with the old omc twins in the 18-20-25 hp range, and if this were those I would blame the gasket just below the powerhead; but this is the first 40 I've worked on, and I wanted to ask folks familiar with this motor before I start tearing into this old motor....
Thanks!
Thanks!
