So I found the one on top, the flathead one and I assumed this was the one for the bottom where I drain it from because there wasn't one on the other side so I figured it was the right one, like on my 9.9 johnson, it is the same, but I later come to find there is another one identical to the top screw on the very bottom of the lower unit, looking from underneath it i was like CRAP, thats why its not filling up right, so I went to put the screw back in to the wrong one that I pulled and it will not go back in for the life of me, the smooth shaft part before the threads will not slide in for some reason and I can barely see in because the oil is still oozing out kind of, am I screwed? Pics ...
