1977 Mercury 1500, Need Help Bad
Ok guys, I have a 1977 Mercury 1500 inline six that will start at home every time I try it but will not run when I get to the lake or will start and then stop like you turn the key off. Some times it will start and when I put it in gear it like I turned the key off. It is driving me crazy...
I have put a new trigger in it and new internal wiring harness in it plus changed out the ignition switch. I disconnected the mercury tilt switch. It also has a new stator.
Can anyone give me some ideas what to check next. Anything will help.
Thanks
bktheking
Re: 1977 Mercury 1500, Need Help Bad
Any water on the spark plugs after it' been run in the lake?
Faztbullet
Sounds like your dropping voltage to switchbox, next time you go to lake take a test light and place it on white wire of box. When engine wont start or quits see if light is weak or off. If off you have a break in wiring(loose/bad pin in side connector) or if still on possible a bad switch box or defective trigger..
There is no water on plugs. As far a wiring problem goes, you said if the tester light is weak or off you have a break in wiring(loose/bad pin in side connector). Do you mean the connector on the switchbox. (white wire)
Faztbullet
Your harness where it plugs into side of engine...
