Re: aphia one and alpha two
Here's the text version:<br /><br />R, MR and Alpha One drives were produced from about 1983 through 1990. Starting in 1991, the Alpha One - generation II drive was produced, an improved version of the original Alpha One (generation one). The Bravo I drive was introduced in the late eighties, may 1988 and was designed to operate under higher stress/torque conditions and had additional features, such as hydraulic trim memory return. Bravo II was a beefier version for non-planing applications taking a large diameter prop (up to 20"). Bravo III has a twin prop configuration (dual counter rotation) for high hp applications.<br /><br />There are several versions of each drive type, including diesel versions and high performance specialty ones. Hope this helps.
