rhillman75
- Jul 28, 2010
- 176
I just traded for this I/O and it is time to winterize it. I know from what I have heard that I need to drain the lower unit lube and refill. I also know I should changed the plugsand the oil/filter. What I do not know is the location of the drain plugs. I understand that there are "2" in the mainfolds, but I do not how many are in the block? I also do not know if I need to "pump" antifreeze and if I should... how much back into the block. I know this has probably been asked alot but the marina wants $325.00 to winterize and I am mechanically inclined and on a low budget considering I am only working part-time. Any advice would be great!
