I am just wondering if someone can help me to decide which prop to order.
I have a 1999 alumacraft magnum 165 with a 1999 40 hp merc 4 stroke on the back and a 6 inch manual jack plate. Right now I have it fully loaded with a 24 volt bow mount trolling motor, a 12 volt back trolling motor, 3 batteries, 2 sonar units, 6 rod holders, 8-12 rods, a whole compartment full of tackle, net, all the normal safety gear, a 20lbs anchor with a 5lbs chain and 100' of rope, a minnow trap, all my rain and cold weather gear, and the bait and lunch coolers. I also have my partners gear with me usually.
I am running a 12 pitch aluminum prop that has been fixed up a few times and am running at the perfect rpms with this prop and hitting 25mph gps speed with all this gear and 2 of us in the boat.
I am just wondering if I should switch to a 12 pitch 4 blade or an 11 pitch 4 blade to get a better wholeshot when I have the livewell full and running? I need a new prop so any suggestions are greatly appreciated.
I also realize that I am way underpowered and am just trying to make the best of what I have for now. I could also just stick with ordering the same prop I have but I would like to get on plane a bit faster when I do need the livewell.
Thanks,
Nate
Thanks,
Nate
