Re: Chrysler Force 15hp Carb. Question
I would check Ebay or search the internet for a carb or carb kit. I have seen used 15HP carbs on Ebay before (Fleabay
) and bought a 9.9 carb for my 89 7.5HP Force (Gamefisher) from Ebay. Have you checked here at the Iboats store for the carb kit? I have found some obsolete parts for my 7.5HP Force by scouring the internet with the P/N, or portion of the P/N.
There isn't much to that carb and I took mine apart to clean it (not rebuild) without a kit, just hope you can reuse the gaskets... (Yeah, yeah, I know, you should replace the gaskets....) I did make a new carb>engine gasket as I wanted to make sure it has a good seal, all other gaskets sealed up OK. If you do take it apart without the rebuild kit, just be aware you might be walking down a 1 way path, cross your fingers the parts & gaskets can be reused...
BTW, what's wrong with your carb?
Have you rebuilt the fuel pump yet? I would as Ethanol will eat, disform and harden the rubber membrane.
