After digesting the responses to my Merc vs Volvo query, I bought a 1986 boat with an AQ131a/175 drive train. Low hours, I think, and good compression.
It has several issues:
(1) Alternator is out of alignment. Is this common?
(2) Push rod setup that unlatches the tilt lock isn't working. I hear this is a somewhat common problem. The fix?
(3) Overheats at high power settings. My take on this is there is probably an air leak in the suction line. Right track? Could be a dirty heat exchanger. There are lots of seals in this system. Am I likely to need a whole set of new ones?
(4) This setup has no front mounts. Seems like a helluva load on the transom, but I don't seen any failures happening. Should I be OK with this?
(5) What's the proper way to trailer this rig? POs' did it resting on the tilt jackscrew, but I don't feel too comfortable with that. There is a support bracket thing in the boat made out of about 3/8 steel rod, but it's bent like a pretzel. Is this supposed to be straight/flat?
Well, this grew into too many questions. Thanks for any answers.
am
am
