I have a Volvo Penta 2.1 liter, 4 cyl, ohc engine. AQ125B. The outdrive is a 270D. When making a turn there is a growling sound coming from the outdrive somewhere. Earlier this summer I replaced both U joints and all gaskets and O-rings in the outdrive tyring to fix both the growling and an overheat problem. The overheat is solved but the growling remains. I used a pipe to try to pinpoint the souce. It's loudest at the upper unit of the outdrive. The bell housing bearing had been suggested by one source but I'm not convinced that's it based on sound source. I'd prefer not to pull the engine out until convinced. Thanks for any suggestions.
