90hp [95 0r96]
:mad:
I have a 90hp evinrude on my 24 ft. pontoon. I've noticed water coming out the exhaust ports. My question, is this normal. I have a good stream coming out the port that lets you know the water pump is working.
trendsetter240
Re: 90hp [95 0r96]
:mad:
Yes it is normal. Water is discharged though the exaust ports to help with cooling. If you have a strong stream from the tell tale then you have enough water pressure in the cooling system.
