Winterizing Mercruiser 5.0, drain plugs
cardsrok
I just recently purchased my first boat, a 98 Baja 180 Islander with the 5.0 220hp Merc. We are going to winterize soon and am wondering how many drain plugs are on the engine. Any help is greatly appreciated. Thanks
Howard Sterndrive
Re: Winterizing Mercruiser 5.0, drain plugs
typically 4
one on each manifold
one on each side of the block
cardsrok
Thanks. I've heard anywhere from 4 to 6, with one in the front under the thermostat and water pump area.
cimy3
Don't forget about the power steering cooler.
somebeach
On my 2001 5.0 EFI there are six plugs. 3 on the left side of engine and three on the right.
Dakota47
Some do and some dont.. take off the hose if your does not have a drain..
chris0061
its best to take the hose off anyway even if it has a power steering cooler drain plug. That's my thoughts anyway.
blouderback
Here's the drain plugs on my 2005 Mercruiser 5.0 carb'd 220HP. There's 5 of them:
