Re: Mercury 115 EFI bogging down
It's a good idea to check your compression to rule that out.
I think that you are having a fuel delivery issue.
One of the first things to check (as already mentioned) is the fuel rail pressure.
There is a fitting on the top of the fuel rail that you can attach a pressure gauge to (I've read of guys using a tire pressure gauge in a pinch)
At idle, you should be getting 38lbs. As the RPM's increase it should increase to 41-44psi.
This test should be performed at the trouble RPM under load.
There's another filter that is on the high pressure fuel pump that is located in the VST (vapor separating tank) that needs to be serviced.
If you are getting low fuel pressure, this filter may need cleaning.
To access the VST you will have to remove the intake assembly.
At this point, I would highly recommend getting the factory service manual to help you out
If fuel pressure is good, the injectors should be sent out for testing and cleaning.
Recently, I sent mine to
http://www.brucatosvs.com/fuel_injector.html
They were a pleasure dealing with.
$25 per injector, before and after test results, new filter screens and o-ring.
This motor uses a Yamaha powerhead. Same one as the F115 up to 2006 if not mistaken.
You can do some searching in the Yamaha/Suzuki section archives
One last thing (as already mentioned), if you keep trying to run the motor hard with fuel issues, you can cause major damage because of a lean fuel condition
Hope this helps you out
Scott
