jbjennings
- Jul 18, 2007
- 3,903
Well,
I finally had to just give up for a while and come back to my old 50horse today......
It had good spark, fuel, and compression but wouldn't hit a lick. After rechecking spark for the 5,000th time, and checking timing, I decided to switch spark plug wires and vrooom, it immediately cranked. The Previous Owner must have switched the coil wires on the terminal block. ....Embarrassed, but glad to have it running......FINALLY!:redface:
Question: How to remove idle needle valve bearing?
Problem #2---system is pulling current with key off. Short somewhere?
I disconnected wires to lower unit, so it's not in the lower unit. Likely places to look?
Thanks for the help so far,
JBJ
JBJ
