Re: Changing the outdrive oil
I think the outdrive oil he is referring to is the fluid in the trim / tilt motor. To be honest, I have recieved quite a few different answers as to what kind of oil to use. Some have said to use regular 30 weight motor oil.... others have said to use transmission fluid.... I recently changed mine and bought "trim and tilt" fluid at Wal Mart. (It is clear - looks like power steering fluid). The fluid I took out was red like transmission fluid. It works with both.<br /><br />To replace, I simply removed the plastic tank, cleaned it good and filled it. It bleeds itself with use.
