eavega
- Apr 29, 2008
- 1,377
I have a '76 70 HP Johnson 70EL76D that is new to me. The guy who sold it to me started it, shifted it through gears, we did a cylinder drop test, etc, so it all checked out. One thing the boat it was on did not have a tach. When I got it installed on mine, I found the tach did not work. I did the Joe Reeves test of swapping the gray wire to the position on the connector strip where the yellow wire coming from the stator is, and that works. I also noticed that the voltage was not going up on the battery (but it wasn't going down either) when the motor was running. All this points to replacing the rectifier, right? Also, is there any harm in running the motor with a bad rectifier other than not being able to charge the battery. Is there any danger in leaving the tach connected to the yellow wire from the stator? Thanks.
Rgds
Rgds
