Beware cheap tools....
Mark42
When mounting the outboard on my boat, I had used two C clamps to hold the motor tight to the transom while marking for the bolt holes. Suddenly SNAP! and one C clamp comes flying off.
This one I had for a few years, used it mostly for gluing up wood. Tighten it up for a serious job and it broke. Yes, it does say "taiwan" on the side.
First time I ever broke a C clamp like that. It pays to buy good tools.
marine4003
Re: Beware cheap tools....
the same can be said for anything..its false economy to buy cheap. Its a waste of time to do jobs half assed,and finally....never spit into the wind..OR pull on Supermans cape...i'm tellin ya..
Haffiman
That is simply a safety measure built in in case you accidentally had your thumb between when tightening. :):)
Mark42
What !!. Do you want a pity party over this ??. :rolleyes:
Of course. Glad to see you picked right up on it. :rolleyes:
yep, I know it was cheap stuff. I have some magnesium alloy super light weight C clamps that have done serious work and never broke. Never found another set like that. But they were not cheap, either.
Hmmmm. Hadn't thought of that! :D
Limited-Time
Its obvious you exceeded the manufactures recommended amount of torque on the t-handle. To blame the Manufacture for your brazen carelessness is just wrong. :p:p:D
Vlad D Impeller
It's always a bit disappointing when a tool fails on the job, whether it is inexpensive or not. However by the looks of it, it seems that you did get your moneys worth out of it.
bruceb58
Not sure you can blame a tool for breaking, no matter what the quality, when you are using it for a purpose it was never intended.
fishrdan
You mean clamping???? He wasn't using it as a sledge hammer, pry bar or gantry crane hook...
I've abused my fair share of clamps and never seen one fail like that. I agree about buying quality, even though I don't all the time. About 25% of my clamps are name brand, others are HF specials. I've never broken of maimed one of the name brand clamps, but have probably broken their number in cheap HF clamps. Though,,, if I I'm going to be abusing a clamp, I make sure it's a cheapie.
Mark42
Yes, I was just tightening it up on the transom. When the broken ends were inspected, there were air pockets in the cast iron! Pretty low grade iron, I guess. And a very course grain.
dlngr
Reminds me of a real el-cheapo porta power[hydraulic jack for auto body work] I bought years ago. Broke every piece I looked at!! Talk about some cheap cast iron! The only "proper use" for the thing was to use it to hold down the box it was shipped in.
Oh BTW-Shame on you for using a c-clamp to clamp something!!
bruceb58
When mounting the outboard on my boat, I had used two C clamps to hold the motor tight to the transom while marking for the bolt holes..
Using it to hold the motor onto the transom doesn't sound like clamping to me. Their purpose in life is to hold two pieces of metal or wood together temporarily while you work on them. Holding an outboard motor onto a transom isn't in their job description.
I have dozens of clamps I use for my welding. Not sure I would use any of them, including the good ones to hold up an outboard motor.
I don't know...maybe its just me. I wouldn't be betting my outboard motor to be held on for the work you described by a c-clamp such as this one, especially one that says Taiwan on the side of it.
dvandsm64
hate to say this. i'm a union worker , but i've snapped a craftsmen rachet. of course i had a 3 ft. cheater and pushed it with my foot. we all learn our lessons.
Moody Blue
I am a firm believer in you get what you pay for, in most cases. I won't get into the details of how I broke a 3/4"drive 36" Snap-On breaker bar :(.
dwco5051
How about a hint such as how long the piece of pipe you slipped over the handle was.
As far as c-clamps go a drop forged one will bend before it will break but you won't find them in the any tool for a dollar display at your local discount store:D
mscher
"This one I had for a few years" is key point here.
20 years ago, China was still emerging from Communist darkenss, trying to join the real world, by mfg, in stone-age factories, cheap, poorly deisgned products, with minimal engineering and little or no quality control. That c-clamp may have been made from "mystery metal" mfg in what is the equivilent, of somebody's barn.
It a whole different game now. China's factories and steel mills are some of the most advanced in the world.
Instead of "make us some pliers and they should look like this..", if Irwin want pliers made there, they surely have design and quality assurance requirements, that the mfg vendor must meet and usually they will meet the requirements, daily.
It not the old China any more.
kenmyfam
Have to disagree with this. Came back from China a few weeks ago and because of the standard of workmanship in their die shops I have to return in a couple of weeks to help them finish the job properly. Their brochures are glossy and they have a lot of state of the art equipment but the bottom line is they are still extremely inexperienced at using it and making quality tooling. The Japanese are very good and the Koreans are doing very well. China is still many years behind in my industry in my humble opinion.
Getting tooling at half price is a false economy when you have to bring it home to finish it properly. I hope my executive management have learned from this experience !!!!:eek:
NYBo
And the C clamp in question wasn't made in mainland China. It was made in Taiwan.:redface:
srimes
" I had used two C clamps to hold the motor tight to the transom while marking for the bolt holes. "
Sounds like clamping to me. He wasn't running the boat with it. You should be able to hand tighten as hard as you can without snapping them, as long as you don't add an extension for more leverage.
