Re: 94 Johnson 50 No Spark
Well today I took it all apart again as in the original troubleshooting. I verified the kill circuit to be good to the power pack; inspected, reconnected, and back probed all connectors to ensure at least that no pins were "pushed"; did the resistance checks on the Stator and the trigger base with all indicating acceptable ranges except the trigger base tests of the blue and green wires to ground. The CDI troubleshooting guide showed to trigger base wires should be short for the white and 25 to 30 ohms for the blue and green. The white was short but the blue and green were open to ground. White to blue and white to green passed the resistance tests of 15-50 ohms.
I put it back together and the danged thing has a strong spark and runs.
I can only conclude that maby a pin was pushed or not making good contact but was corrected unwittingly during the process or worst case there is a positional open in a wire somewhere.
GOD I HATE VOODOO PROBLEMS!
I'll test it afloat tomorrow and report the result.
Steve
