I have just started spray painting with interlux perfection and found out after putting down two coats of lauderdale blue that I am using the wrong size tip and creating an orange peel texture.
So being one to want to do things right, i went to start sanding down the orange peel texture to try again, and thought it was smooth because it feels smooth.
but I went to wipe down with 2333n and found that in certain spots once wetted it still looks like it has orange peel (the way it still reflects the sun)
So now i have decided that I need to do something about it. my question is about what to do next. I have extra primer for two more coats of primer and I have enough blue to start over. with the minute amount of texture left (very tiny but will still be noticable through perfection) if I were to spray a new primekote and sand smooth would that cover up the texture, or will I have to sand all of the blue to solve my problem. My thought is that the primer will build over the texture and give me a new flat surface to work on.
Please help
Please help
