Re: Replacing thermastat mecury o/b 135
If you have a Manual, it's pretty clear. Two bolts hold the thrermostat housing, and the t-stat comes right out. When you remove it, clean the surfaces of the head and the housing really well. The gasket is a round washer-like rubber seal, and it has a lip that goes on each side of the thermostat flange. It forms a seal on BOTH sides of the flange, by having the flange in the slot on the inside edge of the rubber gasket.
