1988 88SPL J88MSLCUS
Just got boat back from shop. Put in and ran around the river for a while. Engine runs great and everything is good. After an hour or two of cruising around I feel a minor jolt or almost a hesitation i guess. Like the little jolt you feel when you hit something under the surface very small. Didnt think anything of it until it happened again a few minutes later. At this time I was low on fuel so I thought hmm maybe its just an air bubble so I continued back to the marina. Fueled up and went back out. Its still doing it. I dont think its the engine because the rpms dont change when it happens. Could this be a sign of the lower unit going? It goes in and out of gear perfectly. Also is this a symptom of a spun hub? Let me say however that this is very intermittent. Once every couple minutes or so, especially when getting up onto plane.
