Im working on restoring my boat. I need to get the transom shield off to check the transom. Motor is out and the outdrive is off. The 6 bolts to the bellhousing are rusted and stuck. The 4 bolts to the exhaust riser are removed but the ex will not budge. The trim motor is unbolted but also frozen. The water line nuts are off but it is also frozen.Ive used crc on everything.
Is there a trick to removing these things? Any help is appreciated.
