Fishermark
- Oct 19, 2003
- 5,617
I recently replaced the manifold on a Mercruiser 165, straight six. (Mid 70's vintage). Engine hydrolocked on me last month and I had to get towed in. Discovered cracked manifold. Ordered a new manifold and installed it - riser is like new, so no need to replace it.
I didn't notice any water in the oil when I removed the old manifold, but after starting the engine and running it with the new manifold (on muffs) I noticed the oil on the dipstick looked milky.
Sure enough, water in the oil. Changed oil and put new filter on it. Ran it for about 15 or 20 minutes on muffs. Changed that oil - it looked just as milky.
Here's my questions:
1. After getting water in the oil and solving the problem - and changing the oil and filter - should the new batch still be milky? How many oil and filter changes does it typically take?
2. Should I take the boat out and run it for awhile to truly get it up to temp and help evaporate any left over water?
Just to make sure, I pressurized the engine block - it seem to hold.
I pressurized the new manifold. It held.
I took off the riser and checked - the exhaust cavity in the manifold and riser are nice and black - no evidence of new water. So it doesn't seem to be any way for any new water to get into the oil.... but the second batch sure seemed pretty milky.
Thoughts?
Thoughts?
