1996 115 oceanrunner j115sledr. motor is baffeling me. cold starts fine will run fine for hrs but once gets warn say 20min boat ride it will not restart unless it cools for say an hour. then restarts fine. does not die but when i shut off and try and start say 10min later it will not fire. at first i thought it was flooding out. no did a carb job. kill switch no relpaced new. not powerpack replaced that too. battery cable sound. when this happens and goes into this mode it turns over but have no fire at the plugs. motor is not overheating, has new water pump and over heat buzzer in functioning propperly. has anyone had this problen before. to me it seems that something electrical after it gets warmed up is failing and not sending spark to the plugs. let it sit for and hour and it will fire right up and run again until u turn it off.
