where does the insert go?
bobhol
I am installing a new shift cable and am not sure where the black insert goes and where does the wrap go? thaks ,Bob
bobhol
Re: where does the insert go?
Where??..I looked thru every frame and could not find the insert or black bushing...am I blind ..is my wife right??:)
JustJason
black insert goes/presses/snaps into the gimbal housing from the inside of the boat to the outside. They can be a pita to put in. Have a look from the outside of the boat where the shift cable slides through, if your old one is still in there then just re-use it.
The wrap wraps around the shift cable where it makes it's bends around the exhaust pipe.
