Folks,
I am trying to remove the lower unit to service the water pump. I removed all the bolts and the lower unit fell 1/2 inch and stopped. I removed an access plate on the port side of the engine and found an aluminum water passage I didn't know how to remove. I see the shift rod between the two halves of the motor. I tried moving the flywheel as per the manual but it made bad noises. 2 posts suggest just pushing harder, which makes me nervous. Any advice?
Thanks as always,
Frank
Thanks as always,
Frank
