Gimbal bearing is in,water hose is on and all surfaces are cleaned and ready for bellows and shift cable .What order do I take to install the rest?...and how do you get the new shift cable thru the shift cable bellows ,it just dont fit....Bob
I put the upper bellow on first. I put the side on the transom first. Used the glue, then clamped her, did the same to the bottom then let it sit overnight for the glue to hold it better. Then put em on the outdrive. I didn't use any bellow tools. Should have, but didn't
Actually I am asking both those questions!!Thanks to both of you....What is the black insert bushing in the cable kit? Where does it go?....and am I correct in that the winding around the cable isinstalled just as the cable comes thru the transom on the inside of the boat as a heat shield ?my exhaust manifold is on the other side....hmmm
