Well the wife finally killed the boat/outboard. Rig is a 17' 1978 Silver line with a 1977 140HP Johnson outboard.
Background:
we were out on the water last Sunday and when passing another boat between an island she went 30ft from shore and hit a rock reef. My son and i were facing the rear and seen the motor pop up and then back down. After quick inspection, i started it up and found that it would not engage in forward but reverse would work. the control cables just felt really tight/stiff.
The Damage:
i will have to inspect the transom next spring but right now want to start looking at the outboard.
- the skegg is bent something fierce and the front on the gear case scrapped. but she does not leak.
- What i noticed is that reverse still works the same speed range just the controls are really tight to pull back.
- when i got it in my drive way i pulled off the control cable and manually pushed down the shift rod. i did get it into some gear but it was way out of the rotation of the shifting rotation.
- After a lower unit oil change (no water in the case) i noticed six or seven small metal shavings on the drain magnet. doesn't seem too bad
- Prop still rotates good and when we were reversing home i never heard or felt anything out of the ordinary.
Here is what i was thinking.
Question:
- pull off the lower unit and inspect the shift rod. Can i take off the shift rod cover and inspect/replace that section without pulling apart the whole thing (drive shaft prop etc)?
i hoping it is a damaged shift rod, push rod
- i have bolt pullers and clamp pullers and a had a few engines and transfer cases apart in my time, do i need any special tool to get this thing apart if need be?
Any suggestions/advice would be appreciated.
Background:
The Damage:
Question:
