  #1
Old January 30th, 2004, 11:27 AM
CharlesW CharlesW is offline
Location: Ankeny, Iowa, Sun Valley Lake, Iowa whenever possible:)
Default Pontoon Pitting?
When I cleaned the pontoons on the used Weeres I bought a year ago, I notice quite a little pitting. The pontoons hadn't been cleaned for several years and had a lot of scale built up. I'm pretty sure the pitting was there when I started cleaning them. I used a regular pontoon cleaner so I don't think it was the problem. Is it common to have a pitting or corrosion problem in fresh water lakes if the pontoons are not cleaned? Do I need to do anything special or just don't let it get that bad again?Charles
  #2
Old January 30th, 2004, 12:03 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: Pontoon Pitting?
Charles,When neglected, that's what happens to the pontoons. The best thing you can do from now on is to clean them at least a couple times a year to prevent it from getting worse. My old toons never had a pitting problem(10+ years). But I really believe that was because I took care of it well. I use a product from refrigeration houses, that you spray on or brush on and the toons look like new. Very strong stuff!!! Only takes a half a gallon to do both sides. Brush on,rinse off! Done in an hour! Then I wax them to protect them for the season. They still look good with the boat sitting in the snow in the back yard. Basically, it's coil cleaner. But you need to ask for the "Acidic" cleaner. Bout $10.00 a Gallon, but well worth it. Won't get rid of all the pitting, but sure cleans them up well. Some rubber gloves and a scotchbrite pad works wonders on making them shine. Did the boat sit in the water or was it hauled out every time. Makes a big difference.
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old January 30th, 2004, 05:51 PM
RB:The boat was in the water for a season at a time.I don't think the pontoons were cleaned when it was pulled for the winter. My cleaning of them last fall was probably the first time they had been cleaned for at least 5 or 6 years.It won't get the best of treatment from me since it will be in the water for a season at a time. At least the pontoons will be cleaned when I pull it out for the winter. I'll have to check on the "coil cleaner" for the next cleaning. The stuff I used was quite expensive and didn't work as well as what you are describing. Much of the scale I removed with a 3M pad on a random orbit sander.Charles
  #4
Old January 30th, 2004, 06:04 PM
Ask for "Alumabrite" at an A/C parts house or A/C company. It will do the job!! Start at the top of the toons and work your way down. If you want to spend a "few" bucks to keep them that way, get a product called "Sharkhide" from here. It seals the logs up and keeps them looking new. www.sharkhide.com/
__________________
Rick
  #5
Old January 30th, 2004, 06:12 PM
Thanks RB. I will definitely try the Alumibrite.Might even go the Sharkhide route.Charles
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pontoons Pitting shorty28 Boat Topics and Questions (not engine topics) 15 June 16th, 2009 02:41 PM
Minor Pitting on Axle imported_Warren Trailers and Towing 5 April 14th, 2005 12:27 PM
Pitting on aluminum Duckworth1 Boat Topics and Questions (not engine topics) 3 March 3rd, 2005 03:08 AM
Aluminum pitting epupa Boat Topics and Questions (not engine topics) 1 February 8th, 2004 08:57 AM
metal pitting jpvip Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 December 8th, 2002 08:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
