Hello All,
This is my first post, I have been reading posts for some time.
My issue is that I have a Volvo Penta AQ151 that starts fine, idles fairly smooth and seems to run ok with no load. If i push the trhottle up fact she seems to spit fuel out of the carbs and at times backfires. I have checked the timing, belt jumped a tooth and reset it. I also reset the timing to 6 degrees before TDC per the manual and she continues to act this way.
Suggestions on where to start?
Thanks in advance.
Brett
Thanks in advance.
Brett
