Hey guys, I got a 1988 mercury 90 2stroke 3cyl, I just put it on my boat 2 days ago and the problem I am having is the engine will sometimes cut out mysteriously under load its not always consistant and it will run like its runningon 2 cylinders and seems to smoke a lot. A couple of people I have talked to said it might be a bad coil pack???? It will run perfect for quite a while and then just crap out out of the blue??????? My controls are also making a beep beep beep when the motor is stone cold and all the time
