'92 Sea Ray 180 Mercruiser Alpha v6 4.3L and the engine runs nicely, but I notice that the throttle is very distinct in rpm increments. As I smoothly push the throttle lever forward, the engine doesn't smoothly increase in rpms. It takes most of the stroke, or at least half to get up to 3000ish rpms, and then the last quarter of the throttle modulates well.
What I'm trying to say is that the throttle doesn't behave quite like a gas pedal on a car does. I go from idle, to about 2800 rpms, and then modulation from 3000-4400 goes as expected, but I can't make the engine run at 1700 rpms (or at least I don't remember it wanting to run at this speed). It seems like the engine runs at 700rpm (idle), or 2800-4400rpm, there is no 1200-2300rpm range.
Is this normal?
tia
Is this normal?
tia
