At cruising speed a few days ago I bumped the kill switch by mistake. The boat never re-started and had to be towed in. Motor hardly runs at all. Ran perfectly prior to this incident. 300 hrs on it. Fuel checked out OK, plugs are OK, replaced rotor and cap, replaced IAC valve, checked coil, checked fuel pressure, still wont idle for more than a few mins. Two marine techs still cant figure out the problem. I assume its probably something simple, but at $100.oo an hour, id like to find the problem sooner than later
. Any ideas would be greatly appreciated. Cheers !!
This is my first boat. I am depressed that something so innocuous has been so difficult to fix.
1999 Doral 250SE Cruiser.
350 Mag MPI Bravo III
300 hrs
300 hrs
